3rd Gen Durango 2011+ models
Jeep SRT8 Springs
Old Aug 26, 2014 | 01:35 PM
salrt's Avatar
salrt
Default Jeep SRT8 Springs
OK, so I know this has been talked about before. However, I am seriously considering going with the Eibach 2012-2014 springs for the SRT8 (P/N # 28109.540). The suspensions are basically identical. Weight can't possibly be an issue because the AWD SRT8 Jeep has a curb weight of 5,223lbs and the AWD R/T D is 5,331lbs. That's just over 100lbs, so I can't see that making a difference at all. What am I missing?
Interesting article: http://www.truckinweb.com/editorial/...dodge_durango/
Old Aug 26, 2014 | 02:06 PM
D3-Blk-Hemi's Avatar
D3-Blk-Hemi
Front / Rear Weight Ratio?
Towing or Not Towing?
Old Aug 26, 2014 | 02:11 PM
redalty's Avatar
redalty
Wont work. I can tell you I tried that with the Black Ops coils for the srt when I started and it wasn't even close. The eibach had a lesser spring taste and will result in worse results. There's a reason they aren't listed for the Durango.
Old Aug 26, 2014 | 02:13 PM
salrt's Avatar
salrt
2012 SRT8 55/45; 5,000lb towing
2012 R/T 50/50; 7,200lb towing
It looksl like the towing is a gearbox limited thing. The 2014 SRT8 can tow 7,200lbs now. Again, not sure the differences add up to non-compatibility...
Old Aug 26, 2014 | 02:16 PM
salrt's Avatar
salrt
redalty - are you a distributor for the Black Ops stuff, or just someone that bought the springs from them?
Old Aug 26, 2014 | 02:18 PM
redalty's Avatar
redalty
I'm the one that helped with all the R&D. This is the srt coils installed. Rear was 3.5"+ drop and tires rubbed fenders just going down the driveway.
Old Aug 26, 2014 | 03:34 PM
salrt's Avatar
salrt
Yea, that won't work! Wonder why it is like that? From what I was able to dig-up, there doesn't seem to be that much of a difference. Weight is about the same, distribution is close, etc. Talked to Eibach and they definately aren't going to do anything for the D in the near future...
Old Aug 26, 2014 | 03:55 PM
SteelR/TAZ's Avatar
SteelR/TAZ
I think they are not due to our load leveling shocks in the rear. I think that is the biggest hang up
Old Sep 7, 2014 | 09:48 AM
DJ Hellfire's Avatar
DJ Hellfire
Looks like you have too big of a tire (285 width) which increases your overall rolling diameter of the wheel. Have you tried tires with a lower width/profile?
Also, do you have to have it sitting that low? It looks too low and doesn't really even look that good in the back.
Old Sep 7, 2014 | 04:43 PM
redalty's Avatar
redalty
Guess it wasn't too clear. That is on stock size 265's. Wheels just have more offset than stock. That is what to expect with the Jeep SRT coils instead of the proper Durango coils. I tried the srt coils when I first started and that's how it ended up.
