3rd Gen Durango 2011+ models
Durango 2.5inch lift. suspension help!
Old Jun 2, 2015 | 04:45 PM
  #61
Jimjim123's Avatar
Jimjim123
Just wanted to drop in and say thanks for the motivation. Just received my Rocky Mountain lift and rims. My goal is to squeeze a 33" tire but we'll see how much trimming is involved over the next 2 weeks.
  #62
Jimjim123's Avatar
Jimjim123
Oh ya if you had any installation problems to look out for, please let me know thanks!
Old Jun 3, 2015 | 12:55 PM
  #63
HEMI-WAGON's Avatar
HEMI-WAGON
Hell yeah I want to do the same with mine. Let us know how it fits and post some pictures!
Old Jun 4, 2015 | 11:03 AM
  #64
Jimjim123's Avatar
Jimjim123
Sounds good hemi wagon!! Here is the before picture give me about a week or two and will start a new post with detailed pictures and suggestions.
Old Jun 4, 2015 | 04:21 PM
  #65
Thekoning's Avatar
Thekoning
It should work for ya!
Dont go with too wide a tire, but im sure with a bit of trimming that 33" will fit
Dont forget to post back with pics. Installation can be a bit of a pain, and you may need to buy a washer or two, because two of the bolts are kinda long, thats what my mechanics said anyway.
Old Nov 19, 2015 | 05:21 PM
  #66
1tubadude's Avatar
1tubadude
Post 2015 Dodge Durango Limited
I put the same 2.5 inch lift on my Durango, and 32 inch tires but now I'm getting a popping sound from the rear end when I go over bumps, could it be the sway bar bushings, the mechanic said it could be the sway bar because it is at a different angle and will eventually work it's way in and he has verified that all the bolts are tight.
Old Jul 20, 2016 | 09:23 AM
  #67
cuconwk's Avatar
cuconwk
Cool Help
Ok, So please ignore my previous comments...
I had a friend help me and it turns out it was that he didnt tighten the Control Arm. Thank to RR, who replied and told me what to check, it was found and problem solved. So the Install with instructions was perfect, but me being a Novice in this it took me over 10hours (2 Days) to get them installed. The most problem i have was removing everything. I have 155k miles on my 2011 D, and of course due to Snow, Salt and all of the road mess the bolts were a Bit rusty/hard to remove with my Garage Tools. In either case I am happy with the results, still wish it was a bit taller but this will do. Once i install the new tires (havent decided which or Size) I should get a little more height. But i must say, i think the ride is smoother. But it could just be me, lol Check out the Pics.
