Towing snowmobile trailer with V6
Haven't towed much with my 2013 Durango with the V6 yet but will soon be towing my two snowmobiles on an open trailer. Is it ok to tow in overdrive? Guessing the load will be under 2000 lbs loaded. Towed my 3000 lb boat for short distances and it constantly shifted out of overdrive so I shifted it into 4th manually. Running in 4th the rpm's were really up there so on a longer snowmobile trip that wouldn't be a good thing, engine wise and gas mileage. Will I do any transmission damage pulling my trailer in OD if it wants to downshift at inclines, etc. Thanks.
I have towed extensively with a Kendon trailer and two 500 lb motorcycles, total of 1500 lb. No problem, get 20 mpg. 2013 3.6. On the other hand towed a 12 ft enclosed trailer with 3 500 lb motorcycles, total 3500 lb and I won't do that again. The transmission was very busy and I was often running in 3rd gear. You should not have a problem with 2 snowmobiles and an open trailer.
