3rd Gen Durango 2011+ models
2012 Citadel DRL
Old Dec 29, 2014 | 10:21 PM
silverD11's Avatar
silverD11
Default 2012 Citadel DRL
They come on when i turn the car to run and stay on until i turn it off.
Attached Thumbnails 2012 Citadel DRL-durango-3.jpg   2012 Citadel DRL-durango-2.jpg
Old Dec 29, 2014 | 10:55 PM
Yes they do.
Old Dec 29, 2014 | 11:44 PM
LCF's Avatar
LCF
Well those are not factory installed lights, so i guess the problem is with the connection. Service where you installed them just connected the wires this way, that when the car turns on they turn on. You should connect them through your headlights so they will only turn on when u turn you lights on.
Old Dec 30, 2014 | 04:56 AM
silverD11's Avatar
silverD11
I just found a fuse that is on when the D is put on run and i hook it to it.
Old Dec 30, 2014 | 08:14 AM
FSTDANGO3's Avatar
FSTDANGO3
So You added the LED's at teh Bottom Grill and that is how you hooked them up...GOT IT
NICE JOB
STEVE
Old Dec 30, 2014 | 12:06 PM
silverD11's Avatar
silverD11
Yea, you cant see the LED unless they are on, because they are behind the lower part of the grill where the tow hooks suppose to go.
