3rd Gen Durango 2011+ models
2012 Durango R/T sputters at higher speeds
Old Jan 9, 2015 | 12:02 PM
usmc1811's Avatar
usmc1811
Default 2012 Durango R/T sputters at higher speeds
I just purchased a used 2012 Durango R/T and I am experiencing a sputtering at freeway speeds when applying more gas to increase my speed some. It has been doing this since I bought it a month ago. Did not notice it when I test drove the DD before buying. Anyone have this same issue? Is there a fix or service for it? Any help would be appreciated.
Thanks.
Old Jan 9, 2015 | 03:43 PM
shelbymopar89's Avatar
shelbymopar89
This should be a good read for you, hope it gets resolved soon.
https://dodgeforum.com/forum/3rd-gen...-fishbite.html
https://dodgeforum.com/forum/3rd-gen...some-sort.html
https://dodgeforum.com/forum/3rd-gen...vibration.html
Old Jan 10, 2015 | 07:00 AM
usmc1811's Avatar
usmc1811
shelbymopar89, Thank you for the info. and help.
Looks like I have some work to do.
Again, Thanks!
Old Jan 10, 2015 | 10:43 AM
bbtkd's Avatar
bbtkd
Again, Thanks!
I would also suggest confirming that the air filter is clean, and then dumping a can of Seafoam in the tank.
Old Jan 10, 2015 | 08:56 PM
Wash Man's Avatar
Wash Man
Second the sea foam. It may have just sat too long at the dealer or got a bad tank of gas
Old Jan 11, 2015 | 11:49 AM
usmc1811's Avatar
usmc1811
New K&N CAI installed already (my first mod.) and 2 tank fill ups since buying the DD. And now I have added gasoline additives to help clean the injectors. I'll run her for awhile and see if the sputter goes away.
Thanks for all the input. Between all of us, I hope to get this taken care of, before having to take the DD to a dealership for service.
Again, Thanks!
Old Jan 16, 2015 | 09:21 AM
usmc1811's Avatar
usmc1811
Update: The additives seemed to have worked (for now). It's running smoother at freeway speeds and not sputtering when I give it some gas. I will continue to add additives at every couple of fill ups, just to keep DD running good.
Thanks for the help and suggestions.
