3rd Gen Durango 2011+ models
Who tows with their Durango?
Old Feb 8, 2015 | 09:11 AM
Rammajama's Avatar
Rammajama
Originally Posted by DodgeRT13
That video was a table rock lake. Like I mentioned the RT takes a few miles to load level. When we launched we just came down from the our condos boat parking area after hooking up the trailer. It's only a few meters away from the boat ramp so the RT's load level has not fully pumped up to its normal ride height. That's why you see it sagging in that video.
If you read the nivomat load leveling instructions I says it takes about 2 miles for it to load level.
I tow a couple times every summer about 450 miles each way and never had issues we the rear suspension. We usually go to table rock lake or torch lake and there are lots of hills to climb and many miles of mountain roads.
Hope this helps.
I've been to table rock. Thank god I didn't have to use that ramp! Lol!
Thanks for the clarification. I assumed you had been hooked up and towing for awhile. Maybe there's still hope for the load leveling yet. 😃
Old Feb 9, 2015 | 09:28 AM
coldsteel's Avatar
coldsteel
The load leveling shocks use the suspension's travel to pump up the shocks while driving. If you leave the boat ramp and the local roads are relatively smooth (less suspension travel) then it would take longer than if you had to drive over a bumpy/washboarded road.
Old Feb 9, 2015 | 10:11 AM
Rammajama's Avatar
Rammajama
Yeah I understand that. It's kind of a half azzed system but it better than nothing. With the roads around here, it should level out pretty fast
Old Feb 9, 2015 | 04:24 PM
SHO Rod's Avatar
SHO Rod
Originally Posted by Rammajama
After visiting the Dodge site, I know that it is standard on all models.
I'm curious by this comment. I recently purchased a 2011 Durango Crew AWD with V8 and I specifically asked if it has the load leveling. The sales guy told me it does not, and I've seen some Durango ads that list it, some do not. I will be using my Durango routinely to tow my camper so I'd be very excited to learn that it does actually have load leveling. Is there an easy way to confirm if it does or not?
-Rod
Old Feb 9, 2015 | 05:48 PM
wildspeed's Avatar
wildspeed
-Rod
If you have the trailer Tow Group package you have them.
Old Feb 9, 2015 | 07:50 PM
sinn's Avatar
sinn
You will find that the durango will suck alot more fuel towing than your ram did... I went from an 09 Ram to a 13 Durango and thought the durango would be more aerodynamic with the trailer behind, but the loss of the 30 or more hp really hurt. It will tow but it doesn't have anywhere near the top end power that the ram had.
Old Feb 10, 2015 | 12:01 AM
SHO Rod's Avatar
SHO Rod
I'm not really sure how to confirm if my DD has the tow group or not. It has the Class IV receiver and is pre-wired for a brake controller, but I'm not sure that means anything specific. It's pretty obvious the previous owner never slid anything inside he receiver so I'm doubtful they would have ordered the tow group specifically. Of course they may have bought whatever was on the lot at the time too.
-Rod
Old Feb 10, 2015 | 08:00 AM
Rammajama's Avatar
Rammajama
According to the dodge website, load leveling is standard equipment across all trim models. It says standard, so I take that to mean regardless of whether you have the tow group or not. Even if people don't tow, there's still times where they may have some payload in the truck, 6 passengers, a lot of gear, etc, so it makes sense to have load leveling across all trim packages. There's nothing special or complicated about this load leveling system, it's just a certain type of shock absorber on the rear end.
Doesn't surprise me that your salesweasel didn't know. It's amazing how little some of these people know about the product they sell.
http://www.dodge.com/model-compare/d...ine_mechanical
Old Feb 10, 2015 | 08:04 AM
Rammajama's Avatar
Rammajama
Rod, if you have the receiver hitch, you have the tow group. If you bought your D new then it should be listed on your window sticker, or you can create an account at the mopar owners website and once you do, you will be able to see a build sheet for your D. There's other ways to get your build sheet as well.
Old Feb 10, 2015 | 08:22 AM
Rammajama's Avatar
Rammajama
Double post...
