3rd Gen Durango 2011+ models
tail light swap
Old Mar 13, 2015 | 03:27 PM
Thekoning's Avatar
Thekoning
ya, what about the left and right side tail lights?
Old Mar 13, 2015 | 03:28 PM
Thekoning's Avatar
Thekoning
did you change the tail gate, or just add the tail gate race track light?
Old Sep 15, 2017 | 08:32 AM
heretic1273's Avatar
heretic1273
Default Load Resistor Question
Originally Posted by durangomty
there are two connectors on each side, one .....ed wiring.. hope will help..
led tailight wiring..
Thx for the detailed description! Looks awesome. Question: What type resistor did you use? (Wattage, etc) - I am about to start the conversion ....
Old Mar 17, 2018 | 07:24 PM
Pdela415's Avatar
Pdela415
Default Hello. I've been wanting to
male aftermarket connector
Do the same conversion for a while. Yours looks great .where did you get the wire harness (2014 harness)
Old May 31, 2019 | 10:19 PM
Luis Armando RS's Avatar
Luis Armando RS
Default Do you have the link on eBay to bougth it ?
Hi. Please give me the link to buy it
thanks
it can be done, i got the two taillights for $200 in ebay.. and the lift gate at 100 (total steal), total spent 300. wiring can be done just leave the original wiring intact in case you change your opinion.... you have to put a resistor on the tailights to avoid the blown light warning... total worth it... harder part was to connect the reverse lights due that prior to 2014, reverse are in the tailights and in the 2014 are located at the lift gate.
2014 liftgate installed... worth it
prior to install new 2014 liftgate
Old Oct 19, 2020 | 07:46 PM
Ogon620's Avatar
Ogon620
Originally Posted by FSTDANGO3
SAme tailgate but way different wiring
STEVE
do you have a diagram for the center tail light ??
Old Oct 19, 2020 | 07:53 PM
Ogon620's Avatar
Ogon620
Default Center tail light wiring
there are two connectors on each side, one is used for the reverse, ground and live....the second connector has three wires for the tailights, ground, stop and directionals I used a tester in order to know which wire does what, then I used a 9v battery to check which wire does what , see attached wiring.. hope will help..
do you also have the center tail light wiring diagram ??
And where do you get the resistor ???
Old Jul 18, 2021 | 11:40 PM
paint with pride's Avatar
paint with pride
Talking Not if you know the right people
Originally Posted by Thekoning
You can do it but it costs more than a grand to do
Get the bumper covert at the junkyard and find someone like me that paints from their home I just paint a Lexus and did 5k of bodywork for them for 2500 plus paint. I paint cars all day long that just need paint for 1200-1500 plus paint and it looks like a 5k paint job with a lifetime warranty on the paint. I'm just cold with it. I got tired of not have the things I wanted the way I wanted and learned it just about all. I'm near waco TX
