3rd Gen Durango 2011+ models
Antennas: Fin vs. post
Old Jul 23, 2015 | 01:06 PM
Orin500XL's Avatar
Orin500XL
Default Antennas: Fin vs. post
Most later model cars are using the shark fin antenna versus the older post style, presumably for stylistic reasons. However, my recent unscientific test clearly favors the post antenna over the shark fin regarding reception.
My '12 Crew has the post and my wife's '14 Avalon has the fin, we're both subscribers to Sirius and we both listen to the same stations. And we both frequently travel the same routes in and around Annapolis, Maryland. I recently drove her car along some familiar routes and was amazed at the clear and unequivocal differences in the Avalon's reception. While the differences could be attributed to the manufacturers' specifications, I suspect that most the stuff is off-the-shelf industry-wide equipment, i.e. no proprietary secret stuff. So any anomalies could rightly (for us non-technical guys, anyway) be attributed to the antenna.
Here was the test: open road, clear suburbs, forested suburbs, and city.
OPEN ROAD: Both had excellent reception. However, when going under an overpass the post maintained reception during the entire event but the fin would often loose reception underneath but regain it when it re-emerged.
SUBURBAN: "Open" suburban areas; the post had no disruptions while the fin had very good reception with only occasional disruptions. In forested suburban areas the differences were clear -- the fin was disrupted noticeably more often than the post and for longer periods. On a suburban road with a moderate tree canopy the post again outperformed the fin, having fewer and shorter disruptions. On a suburban road with a heavy tree canopy the post suffered 2-3 reception losses of 3-5 seconds, while the fin lost reception at least 50 percent of the time.
CITY: As expected, reception is diminished in relation to the height of the buildings, but again the post clearly provided good reception where the fin often cut in and out.
All of which probably proves nothing, I guess.
Anybody here with a fin antenna suffering from unintended or prolonged reception disruption due to natural and man-made obstacles?
Old Jul 23, 2015 | 01:24 PM
SHO Rod's Avatar
SHO Rod
I'm not sure what the antenna gain numbers are between the post and fin antennas. The ground plane, antenna matching, and, probably of most significance, receiver gain of the head unit could all play a role. Even differences in weather (cloud cover, humidity, time of day/interferers/traffic) could have a pretty significant impact. So, as you noted, there are a lot more factors involved here than just the geometry of the antenna.
If you were to swap out your post antenna for a fin antenna available for a Durango (not sure if they ever were on the Durango) and try the test again, that would make the antenna and the weather the only major variables.
-Rod
Old Jul 23, 2015 | 04:08 PM
BadBenz94's Avatar
BadBenz94
-Rod
The fins are now standard on the 2014 on up so it should be an easy test(minus $).
Chris
Old Jul 25, 2015 | 02:01 PM
2011CrewLuxSC's Avatar
2011CrewLuxSC
personally, I like the post antenna on my '11 Crew. if I had an R/T without roof rails maybe I'd go for the fin over the post. but on mine with the rails the stubby black post fits right in. and I do get very good reception.
Old Aug 14, 2015 | 09:35 AM
trax95008's Avatar
trax95008
hey Orin, just so you know, the "fin" vs "stub" only affects FM reception. the Sirius antenna is a separate antenna, at the base and is essentially the same antenna used with both styles. (fin or stub) its really hard to compare satellite reception between different vehicles. you would have to spend a lot of time in both vehicles, driving the the same route often to get a "feel" for the reception. the actual reception is always changing at any given moment due to the satellites being in orbit and always moving.
Old Aug 18, 2015 | 06:55 AM
GotRPM's Avatar
GotRPM
Cool
... the actual reception is always changing at any given moment due to the satellites being in orbit and always moving.
The satellites used for radio, communications etc. are geosynchronous - they orbit around 22,000 miles up and never change position in the sky.
Old Aug 18, 2015 | 09:37 AM
trax95008's Avatar
trax95008
from the research i did a few years ago, that is true for XM, but not for Sirius. XM satellites are geostationary, and Sirius are geosynchronous.
