3rd Gen Durango 2011+ models
"Pinch Weld" DIY...
Old Aug 26, 2015 | 04:34 PM
St.Char's Avatar
St.Char
Default "Pinch Weld" Adapter DIY...
Here's a great way to lift your Durango while utilizing the jack points. I used (2) hockey pucks. Cut the first one in half, separate the (2) halfs by leaving about a 1/4" between the two. Place them on top of the other hockey puck and use (2) screws on each half for a total of four screws. After they are secure, place tape over the screw heads to protect the frame rail. Presto! You now have a Pinch Weld adapter. Place it on the saddle of your floor jack and you're ready to go. Good Luck!
Old Aug 26, 2015 | 08:14 PM
Hope no Canadians see this desecration!! ; )
Old Aug 28, 2015 | 11:39 AM
ufokillerz's Avatar
ufokillerz
i made my own with a single puck. plopped it on my miter and set cut depth, slide on slide off. all done!
works well, for a dollar or 2!
Old Aug 28, 2015 | 05:14 PM
MIKEon22s's Avatar
MIKEon22s
You no good pucker
Old Aug 28, 2015 | 06:29 PM
St.Char's Avatar
St.Char
Originally Posted by MIKEon22s
You no good pucker
Haha...at least it does make lifting much easier.
