Rocker panel removal
It must be intuitive. The service manual skips right over that step and goes straight from removing the front fascia to removing the rear lower mounting bolts.
From the drawing it appears there are two bolts on the lower rear and one bolt that would be accessed through the open door. I'll dig around some more to see if I can find anything on removing that lower rocker panel....
-Rod
-Rod
Thanks for all the replies. I can access 2 bottom screws from the back side of the rocker panel. However to remove the fender from from the body, I have to remove the rocker panel because it covers bottom part of the fender. Rocker panel is held in place by plastic clips. Looks like I have to break these clips to free rocker panel. 2011 DD.
