3rd Gen Durango 2011+ models
Loose gas cap
Old Feb 21, 2016 | 01:07 PM
zaktrafton's Avatar
zaktrafton
Default Loose gas cap
2013 Hemi Crew
Loose gas cap message appeared yesterday. Tightened gas gap, still seems a bit loose. 5-10 restarts later and still there. Should I just replace the gas cap? Something else?
Old Feb 22, 2016 | 11:18 AM
usmc1811's Avatar
usmc1811
I've read a few post with the same issue. Gas cap were replaced.
Old Feb 22, 2016 | 02:35 PM
zaktrafton's Avatar
zaktrafton
They are $12 at Oreilly's so I'll try that.
Old Feb 22, 2016 | 03:01 PM
A lot of times only OEM gas cap will work.
Old Feb 22, 2016 | 03:09 PM
J6L's Avatar
J6L
If you have not done so, I would drive the car for a week or so to give the system plenty of time to reset. Another option and it's free, is to disconnect the neg' side of the battery for a couple of minutes. Be sure not to let the neg' terminal touch any metal. This procedure has it's issues such as loosing your personal settings; for example your programed radio stations. After you reconnect battery terminal, start and see if the light is off and stays off. Good Luck
Old Feb 22, 2016 | 11:50 PM
roogie's Avatar
roogie
Heh, how awesome is that graphic. Hope it's a simple fix.
roog
Old Feb 23, 2016 | 03:07 AM
zaktrafton's Avatar
zaktrafton
roog
Wife called me and said, "the car has a wierd light on the dash that looks like a lugnut is loose." LOL.
She sent me a pic and I told her to check the gas cap.
Old Feb 23, 2016 | 11:07 PM
roogie's Avatar
roogie
I'm just glad it tells you on the screen!
roog
Old Feb 26, 2016 | 01:21 PM
zaktrafton's Avatar
zaktrafton
roog
I put a little oil on the gas cap rubber o-ring. The light went away for 2 days then came back.
New gas cap $12 has fixed it so far.
Old Mar 14, 2016 | 06:40 PM
roogie's Avatar
roogie
Well now my gas cap icon just came on too! ha!
roog
