3rd Gen Durango 2011+ models
Radio & Dash Upgrade
Old Mar 4, 2016 | 09:21 AM
cuconwk's Avatar
cuconwk
Exclamation Radio & Dash Upgrade
Morning All,
Anyone know if or has tried, to upgrade the 2011 Radio & Dash to the 2015? Im willing to change it all out, but want to check if anyone has tried or if it all possible?
Old Mar 10, 2016 | 05:30 PM
madd macky's Avatar
madd macky
Sounds expensive... I'm interested though.
Old Mar 11, 2016 | 03:43 PM
03neonRT's Avatar
03neonRT
I'm sure you could get the physical dash and surrounding components swapped over, after all, the underlying car is basically still the same.
However, I doubt you could get the UConnect 8.4 system and the 2014+ gauge cluster working, since that wiring and data bus is entirely different, and there's a ton of interoperability between all of these systems now. Sure, you could rewire the entire car, but that would be expensive and time consuming. Even then, I don't even know if it would be glitch free at that point. Good luck if you try though!!!
