3rd Gen Durango 2011+ models
2011 Dodge Durango Citadel Liftgate won't open
Old Jan 20, 2017 | 02:14 PM
2011durangocitadel's Avatar
2011durangocitadel
Default 2011 Dodge Durango Citadel Liftgate won't open
Hi there,
Our 2011 Dodge Durango Citadel Liftgate would not stay open once opened (I believe the smaller strut must need to be replaced to stay open) and now it will not open at all. It beeps like it will open but does not go up, then beeps back closed. Is it the larger strut, or could it be the 30A fuse, or is the TSB update I have read about? It is not under warranty and we are hoping to avoid a huge dealer bill.
Thank you
Old Jan 20, 2017 | 03:56 PM
Check the fuse and see.
Old Jan 20, 2017 | 06:23 PM
DodgeCares's Avatar
DodgeCares
Originally Posted by 2011durangocitadel
Hi there,
Thank you
Hi 2011durangocitadel,
I'd be happy to check your VIN to see if anything comes up that may be relevant in terms of TSBs for you. Just send a PM if I can help.
Kori
Dodge Social Care Specialist
Old Jan 20, 2017 | 08:57 PM
2011durangocitadel
Default Vin #
Kori
Hi Kori,
Our VIN is 1D4SE5GT1BC692832
Thank you for checking.
Old Jan 20, 2017 | 10:58 PM
wildspeed's Avatar
wildspeed
Hi there,
Thank you
does it open by hand ?
Your hydraulic/gas strut is probably gone and the powered one can't push the lifgate.
I have a 2011 too and going to have to replace the strut for the second time.
Old Jan 22, 2017 | 02:20 PM
SHO Rod's Avatar
SHO Rod
^^^ Agreed. You symptoms are consistent with worn gas struts for the liftgate.
-Rod
Old Jan 23, 2017 | 12:17 PM
DodgeCares's Avatar
DodgeCares
Hi Kori,
I did respond to your private message--if you wanted to edit or delete the post with your VIN just for privacy's sake, go ahead!
Kori
Old Jan 23, 2017 | 12:25 PM
2011durangocitadel
Thanks for your help. Yes we have had to replace it before too but last time it opened at least and didn't stay up. It doesn't open at all now. We have ordered both struts and will replace them and go from there.
