Inverter wiring
I wanted to install my old inverter from my 2002 Chevy Suburban into my 2017 Dodge Durango. The inverter running at 350W, and 120V AC output, would calculate to be around 30 AMPS running from the inverter. I found a Fuse that would use a inverter, max of 30 AMPS, and its for a factory installed inverter. (I didn't chose that option.) I found the fuse, and found where it would be. Now my problem is what wiring harness it is (I saw one big one, and one little one, and the seats are heated.) Anyone have some diagram of that fuse? I want to know where to plug it in, and on the big harness, I saw 3 empty ports on it. And if anyone knows a wire that goes to the battery or goes to a 30 amp fuse let me know on this post, or just respond. Thanks
