2014 durango key fob
I got a warning that the key fob battery was low so i went to the store got a new battery and changed it in the parking lot. Know the car is saying that there is no key fob. is there something special that has to be done after changing the battery..FYI i am stuck in a parking lot on a sunday...i need help ASAP!
Does it work to lock and unlock the doors? If not, as someone else mentioned, the batter may not be installed correctly.
If you confirm your battery is properly installed, your owner's manual should tell you where to position the fob to at least get the Durango to start.
-Rod
-Rod
