3rd Gen Durango 2011+ models
2013 Durango Citadel Interior Lights Issue
Old Sep 26, 2017 | 07:43 AM
coldsteel's Avatar
coldsteel
Originally Posted by Waynead
I don't know if it's a similar problem, but I do know that in some vehicles in you connect a trailer that has LED lights, the trailer lights won't work properly. The solution is to wire an incandescent bulb into the circuit. Then they work. Apparently the circuit needs to see the resistance of an incandescent build to work properly.
So maybe your circuit also need to sense that resistance, hence it works when you leave one incandescent in.
If the BCM is cutting power because it thinks the bulb is 'out' then it is easy to install a resistor across the circuit to fool the BCM into thinking there is a higher wattage device on the line without the light source of an actual bulb.
