No crank no start
As I said in the title I'm experiencing the same issue with my 2013 Dodge Durango. It continues to not crank nor start after putting a brand new battery and starter in. I can manually get it to crank over by using a manual ignition switch. Mine is also saying press clutch and push start as you know the Durango doesn't have a clutch cuz they're all automatics. What do I do to fix this?
respectfully
William Eslow
respectfully
William Eslow
I’m having the same exact issue on my 13 citadel… randomly won’t start, I’ll hear one solid CLICK(sounds like from the starter) but nothing happens..all my lights works just fine…. I’ll even have SOME luck sometimes when I use the actual key to start it instead of push button.. just had Goodyear check it and they said the starter was good but the battery wasn’t… got a new battery put in and less than a week later same BS!!! Any help??
