3rd Gen Durango 2011+ models
No crank no start
Old Sep 28, 2017 | 03:32 PM
gavfor1's Avatar
gavfor1
Default No crank no start
2013 Dodge Durango The vehicle will not crank or start
Old Sep 28, 2017 | 03:39 PM
how's the battery?
Old Sep 28, 2017 | 03:48 PM
gavfor1's Avatar
gavfor1
The battery seems fine. The lights radio and everything else works.
Old Sep 28, 2017 | 03:55 PM
Prospect62's Avatar
Prospect62
Is the key fob remotely locking/unlocking the doors? Is the Durango sensing the key fob is basically what I'm getting at. If not try another key fob or replace the key fob battery. Or if you can't, try pushing in the start button with the keyfob.
Battery is always a good start, as mentioned. But if your lights, bells, chimes, radio, etc work it may be the fob not being detected. Just a thought.
Old Sep 28, 2017 | 03:57 PM
gavfor1's Avatar
gavfor1
The doors do lock and unlock, but it doesn't have the option to remote start.
Old Sep 28, 2017 | 04:08 PM
DodgeCares's Avatar
DodgeCares
Hi gavfor1--please feel free to reach out to us if you need further assistance at the dealership level. We're happy to make an appointment or follow up!
Kori
Dodge Social Care Specialist
Old Sep 28, 2017 | 04:12 PM
Prospect62's Avatar
Prospect62
No I'm not saying remote start. I'm asking if the truck recognizes the key fob. Like when you're sitting in it.
I'm gonna get yelled at for linking to YouTube. Just trying to help.
Old Sep 28, 2017 | 04:29 PM
gavfor1's Avatar
gavfor1
We are experiencing a lot of rain here and apparently the starter got wet. I tapped it a couple of times with a hammer and it started right up.
Old Sep 28, 2017 | 04:48 PM
Prospect62's Avatar
Prospect62
Well, starters are designed to get wet. When you can, check the connections to the starter for corrosion and consider replacing it. That's not normal.
Old Sep 29, 2017 | 06:57 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
usually tapping on the starter to get it to turn over is a sign that the starter is on its way out, the brushes are worn and not making good contact all the way around, tapping it moves things just enough to get contact, but if it stops on that spot again it will likely present the same symptoms
