AWD won’t kick in
to clarify...is this the awd or 4wd? AWD have no low and 4wd do.
If its AWD...is the abs light on?
if you have the mp2010 transfer case...it uses an open center differential...the non-slipping wheels are only transfered power by the abs applying the brakes to the slipping wheels...so if the abs system has a fault...it drives like a 2wd.
It is AWD my front wheels, they are not getting any power. No my ABS light is not going off just the Traction control light.
traction control and abs both use the same wheel speed sensor data to operate. get the codes read and post them here. you will need a full function scan tool to read chassis related codes. A code reader can not do this.
