3rd Gen Durango 2011+ models
problem
Old Apr 3, 2018 | 02:51 AM
amjed's Avatar
amjed
Unhappy problem
hello
i have problem with my durango 2011
this case when i open the door sill few sec. and gone see the video atached
File Type: wmv
Old Apr 3, 2018 | 07:29 AM
Need to provide more information. Looks like the vehicle wont start. What happened?
Old Apr 4, 2018 | 01:35 AM
amjed's Avatar
amjed
no every thing is normal engine start normal and the gage work normal
but when i open the door the gage not stable like video
Old Apr 4, 2018 | 07:49 AM
SHO Rod's Avatar
SHO Rod
I hear a clicking that seems to correlate with the bouncing of the needle. Are you able to determine where the clicking sound is coming from (under dash, under hood, TIPM, etc.)? Does the same thing happen if the driver's door remains closed but one of the other doors is opened? Have you checked the condition of the battery and made sure all of the fuses are still good?
-Rod
Old Apr 5, 2018 | 01:19 AM
amjed's Avatar
amjed
i think the sound in dash needle of rpm ... and yeh if i open any door and the driver's door closed it will happen ..
am not check any fuses yet
Old Apr 5, 2018 | 02:32 PM
DodgeCares's Avatar
DodgeCares
Originally Posted by amjed
hello
Hello amjed,
I was able to view the clip you attached and do understand why this concerning. Although you've got some great advice, if you decide to have this looked at by your Dodge dealer, please let me know. Our team is available via direct message and would be happy to help with this process.
Jasmine
Dodge Social Care Specialist
Old Apr 8, 2018 | 01:47 AM
amjed's Avatar
amjed
thanx to every one
i solve this problem by opening the dashboard and saw the deshli of gage was broken i fix it and done .
Old Apr 8, 2018 | 09:01 AM
SHO Rod's Avatar
SHO Rod
Good job finding the issue and fixing it. Thank you for following up with what you found, although I think there may be a translation or auto correct issue. I'm not sure what a "deshli" is. Would you mind a bit more explanation in case another forum member has the same issue in the future?
-Rod
Old Apr 9, 2018 | 02:06 AM
amjed's Avatar
amjed
deshli mean ( gear lever ) it position behind the cursor of rpm
it interlock by together and let the cursor mov for up or down
when i open i found it broken
