3rd Gen Durango 2011+ models
2011 DD map update
Old May 2, 2018 | 07:54 AM
hoeky's Avatar
hoeky
Default 2011 DD map update
I have the 430n radio and needed a map update, I had done an update of uconnect to the 50xxx black UI for the system before the map update. now with the new USB and micro flash update I get the error PND did not update and can get no further. I tried to do this twice, do I have to go back and start the update process from the beginning? with update 22xxxxand newer?
thanks in advance for the help
bob
Old May 5, 2018 | 05:30 PM
hoeky's Avatar
hoeky
ok how about this ---I need a link to all the old versions of the software updates and map updates , in order to straighten my system out and put it back to normal . its colors are all messed up because of the 50xxx update
Old May 8, 2018 | 09:41 PM
NY-Durango's Avatar
NY-Durango
Just to let you know I have the 2011 Durango and I also did the download to update the radio and had the black background. In 2016 I purchased the map updates and it installed without any problems but it changed the background colors to the original blue. You may be having a problem with the new flash update. My radio worked perfect after installing the new map update but unfortunately they are still way behind the times. I just use google maps on my phone now. Good luck with your install.
Old May 10, 2018 | 08:59 PM
hoeky's Avatar
hoeky
thanks
Old May 13, 2018 | 11:33 AM
hoeky's Avatar
hoeky
so is this a Garmin, Dodge or Uconnect problem? I really need help!
Old May 15, 2018 | 07:14 AM
hoeky's Avatar
hoeky
After talking to Garmin Support, it has been determined that the sd card didn't have 2 files needed to update correctly, it has been returned to them for replacement.
Old Jun 2, 2018 | 09:02 AM
hoeky's Avatar
hoeky
UPDATE Garmin sent new update software and all is good ,update went without a hitch.
