Display keeps showing FCW Failure
I have a 2011 Dodge Durango Crew Lux model with 190329 miles on it. For about the last month the electrical system has gone completely out of wack. What first started happening is I would get the ocassional FCW Failure in the dash along with Automatic Cruise unavailable. Once those warnings would flash the entire Information Display would turn off. After the info display turned off the stereo would also turn off (Uconnect RHB w/navigation) for a while everything would turn back on and only the battery light would stay on. I was nervous that it was the alternator again which I had previously replaced prior to the recall. I brought it in to get checked and was told nothing was wrong with neither the battery nor the alternator. This issue has progressively gotten worst with all the restart of the display and infotainment system every few miles and errors for everything from the park assist system to the blind spot monitoring system. Anyone else have this issue or know how I can maybe address it?
For the FCW and Cruise control issues, check the speed sensors. I had a 2011 Citadel that had the same issues with those and i replace the speed sensors and those issues immediately disappeared. If you take it to a parts store, they might be able to determine the side of the sensor so you don't have to replace all 4. Something to try
