3rd Gen Durango 2011+ models
2014 durango turn signal
Old Aug 5, 2018 | 03:10 PM
reiterrf's Avatar
reiterrf
Default 2014 durango turn signal
I have a 2014 durango and got a right front turn signal out message. We replaced the traditional bulb with an LED bulb and now the front and back light work and are in sync but the mirror turn signal is blinking at double speed. any ideas?
Old Aug 5, 2018 | 05:16 PM
SHO Rod's Avatar
SHO Rod
It sounds like you did not use a load resistor when you installed the LED lights. The hyperflash is common when switching to LED bulbs if you do not install a load resistor.
-Rod
