3rd Gen Durango 2011+ models
Dodge Durango R/T 2015, battery specifications
Old Sep 6, 2018 | 07:50 AM
mzj's Avatar
mzj
Default Dodge Durango R/T 2015, battery specifications
Dodge Durango R/T 2015, battery specifications are required to replace the fading battery
12V CCA 700 is written on the top cover
As per the local battery supplier the rating is 12 V 100 Ah. Please advise on the exact specifications to buy & replace the factory battery
Old Sep 6, 2018 | 07:56 AM
Take it to walmart or any auto parts store. They will match up a new battery to the required specifications for your vehicle. Will even install it for you.
Old Sep 6, 2018 | 12:57 PM
SHO Rod's Avatar
SHO Rod
Automotive batteries, at least in the US, are typically categorized by battery group and Cold Cranking Ampere (CCA) ratings. Batteries rated just by voltage and amp-hour rating tend to be more universal fit general purpose batteries. As mentioned above, you are probably going to be better off going to an automotive parts store or department store with an automotive department and order the largest CCA battery you can afford for the application.
-Rod
