3rd Gen Durango 2011+ models
Aftermarket or factory tow hooks?
Old Feb 26, 2019 | 11:36 AM
dodgetruck2's Avatar
dodgetruck2
Default Aftermarket or factory tow hooks?
Just bought the wife a 2015 Durango AWD Citadel package and we've already managed to get it stuck in the snow, much to my disappointment i found Dodge again failed to install or provide tow hooks or any decent place to hook onto it, why these are not standard option ill never know but anyway. I can find pictures online of what appears to be factory tow hooks but when i look up in the vehicle lookup to order parts i can't find anything. I am planning on installing a rear receiver so atleast there will be a place to hook i would really appreciate front tow hooks also. Looking at the picture it appears you need a different bumper or at least the mess screen is different? any input would be appreciated thanks
Old Feb 27, 2019 | 06:46 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the factory tow hooks from a grand cherokee should fit, but as you mentioned the block out panels would be different, you can likely just remove them, or cut them yourself if you cant find replacements (i have no clue if the jeep panels would fit, id expect the bumpers to be too different, but ya never know)
Old Feb 27, 2019 | 07:29 AM
GDM's Avatar
GDM
Just curious what kind of tires do you have on the Durango and depth of tread? Many "all season" tires don't cut it in snow, yet we run them thinking the AWD system will compensate for the tires. Have you considered running dedicated winter tires for your climate? Tow hooks might be my second option.
Old Mar 20, 2019 | 11:24 AM
dodgetruck2
Tires are good condition all season, do recall brand, fairly deep tread, im not upset we got stuck, drift was 2-3 ft deep and 20ft long, ive been really impressed with what this thing does get through to be honest especially with the T/C off, im just upset that once we were stuck there was abosolutely no where to hook a rope to front or rear, as i mentioned i do plan to add a receiver hitch to it but that only gives a rear hook point, and i really prefer pulling a stuck vehicle forward if possible because backwards is when you rip things off
Old Mar 20, 2019 | 11:41 AM
dodgetruck2
ill have to research this some then, thanks
Old Aug 19, 2019 | 01:37 PM
dodgetruck2
Reviving this dead topic as winter fastly approaches again, I still haven't figured much out. I have holes in the frame for what looks like a factory hook setup but the front screen doesn't have the knockouts for tow hooks access
Wondering about an RV tow bar setup the little holes to cut for them would be better then half the bumper for tow hooks
Old Aug 21, 2019 | 03:21 PM
1DigitalArtist's Avatar
1DigitalArtist
Been looking into this myself for my overlanding needs, TLDR my only option for tow hooks up front is cutting out the bottom grill and getting it welded/fabricated. The SRT for some reason doesn't have the mount for the tow hooks the other models do, plus the standard ones look hideous. Maybe because its covered by the grill anyways is why the SRT doesn't have the mounting point?
Old Aug 22, 2019 | 06:16 AM
shrpshtr325
THE ULTI-MOD
SRT probably doesnt have mounting points because it was intended to be a 'performance' car in SUV guise, SRT is Street and Racing Technologies (iirc) so there was 0 intent that an SRT would ever be used off road when it was designed. . . .
Old Aug 22, 2019 | 10:09 AM
ol' grouch's Avatar
ol' grouch
A while back I pulled a bunch of tow hooks off F-150 and Furd Expeditions at the bone yard. Good heavy steel with nice bracing cast in. (I guess Furds get stuck a lot.) They have two good sized holes. You'll need to drill holes to mount them and as for the bumper cover in front, you'll have to notch or cut openings for them.
Old Aug 22, 2019 | 12:49 PM
1DigitalArtist
That's where they messed up, this thing Is faster than a Hellcat Gladiator for $150k+ lol. Im not doing any rock climbing, but handled Devils Cove, and most of Death Valley wonderfully. Still has power to do 0-60 in 4.3 with 32" All terrains and a 2.5" lift.
