3rd Gen Durango 2011+ models
Sunroof seal leaks
Old Jul 22, 2020 | 12:30 AM
Musa Conteh's Avatar
Musa Conteh
Question Sunroof seal leaks
Sup I’m new to page big respect to everyone. Got a 12 Citadel that leaks water through the sunroof Seal when it rain. Has anyone had this issue before? What’s the cheapest way to fix it.
Old Jul 22, 2020 | 05:05 PM
SHO Rod's Avatar
SHO Rod
Welcome to the forum! Which "seal" are you referring to? The seal between the sunroof and metal roof of the Durango is not really expected to keep water out. There are drains below the roof to address water that makes it past the debris seal. If those drains get plugged though, then water can overflow the drain rails, get on the headliner, and dribble in to the passenger compartment. If you have water coming in the passenger compartment and a wet headliner, you're probably looking at plugged sunroof drains rather than a bad seal.
-Rod
Old Oct 15, 2023 | 04:03 PM
XxCotHGxX's Avatar
XxCotHGxX
Default What do you use to clean the drain tubes.
Originally Posted by SHO Rod
... There are drains below the roof to address water that makes it past the debris seal. If those drains get plugged though, then water can overflow the drain rails, get on the headliner, and dribble in to the passenger compartment. If you have water coming in the passenger compartment and a wet headliner, you're probably looking at plugged sunroof drains rather than a bad seal.
-Rod
I looked at my drain holes and they seem unobstructed. What do you recommend I use to go down the tube to make sure there isn't some crud?
