3rd Gen Durango 2011+ models
Humming noise.
Old Mar 17, 2021 | 12:39 PM
Roddrickblow's Avatar
Roddrickblow
Default Humming noise.
I just purchased a 2013 Durango Crew and when I get it up to speed I hear humming noise coming from the top of the dash, like between the window and dash. I had the windshield checked and it's sealed. Whatever the noise is it seems like airflow is causing it to happen but having a hard time trying to put my finger on exactly what the problem is. Any ideals?
Old Apr 13, 2021 | 10:07 AM
ExP213's Avatar
ExP213
Default Cowl
Sounds like your cowl is warping causing the rubber to vibrate against your windshield.
Old Apr 14, 2021 | 12:32 AM
Vimes's Avatar
Vimes
Do you have a hood deflector on it? This was a problem on the GMT800 Silverados, install a deflector and you get a fluttering noise which is caused by the wind flow change hitting the rubber strips running up the side of the glass. The fix on them is to use flowable windshield sealer to seal the rubber strips down the side of the windshield down. No idea if the Durangos have the same issue, but it would be a quick check to use masking tape to run down the sides of the windshield and see if it goes away. You could do the same on the cowl to see if that's the problem. Once you identify with the tape, you can do a permanent fix.
Old May 3, 2021 | 02:22 PM
RamedHemi's Avatar
RamedHemi
could be the wipers, push them down and see if goes away. I think wipers sit too high when off.
Old Jun 21, 2021 | 04:14 PM
cecibud's Avatar
cecibud
I have a 2014 Citadel that has developed a noise on the right front dash within the last 2 years. At first, I thought it was a speaker going bad as it has that kind of sound/hum. It usually only happens when going at faster speeds though, especially on interstate. The sound has now moved into the center of the dash and is appearing more often. I read above, and not sure if it's the same thing, but now I do think it might be something in the engine compartment. Any help is appreciated and thanks. Love my Durango!
Old Jun 22, 2021 | 01:00 PM
DodgeCares's Avatar
DodgeCares
Hi cecibud,
Sorry to hear of the trouble you’re experiencing. If you decide to address this concern with your certified Dodge dealer, please feel free to send us a private message. We would be happy to provide you with an additional layer of assistance for that process.
Rob
Dodge Cares
Old Jun 22, 2021 | 06:29 PM
cecibud's Avatar
cecibud
Thanks for replying. Are you saying dealership may know whats wrong when I turn it in? Last time I went in for service, they said they might have to go into dash so I said no at moment as they didn't recognize my description. I do want to get it fixed as it has become annoying and occurs more often. Thanks again
Old Jun 23, 2021 | 12:40 PM
DodgeCares's Avatar
DodgeCares
Hi cecibud,
We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support via private messages.
Rob
Dodge Cares
Old Sep 16, 2024 | 08:44 AM
Lee Norris's Avatar
Lee Norris
Default Wind noise
I have a 2015 Hemi Durango and experience the same noise at 70mph and above is this your experience
thanks
lee
