3rd Gen Durango 2011+ models
Passenger window only goes up or down a few inches at a time!
Old Apr 8, 2021 | 03:06 PM
Swedefj40's Avatar
Swedefj40
Default Passenger window only goes up or down a few inches at a time!
So my wife's 2011 Hemi Crew's front passenger window only goes up or down a few inches at a time. It does this from the driver side's passenger window switch as well. Any ideas on what is the issue?
Here's a video of the issue...
... the initial click you here is me activating the switch and holding it up (or down) but as you can see the relay clicks after a second or two on it's own and it's not me letting off the switch. I removed the motor and tested it out and it runs fine with a 12 v source. The relay it activating even without the motor connected when I hit the switch and stops on it's own too. Having the motor connected makes no difference. I've tried the relearn procedure but no change.
Old Apr 13, 2021 | 11:11 AM
Swedefj40's Avatar
Swedefj40
Anyone?
Old Dec 25, 2021 | 04:34 PM
Swedefj40's Avatar
Swedefj40
Found the fix... Window fix
