3rd Gen Durango 2011+ models
2012 crew ETC light
Old May 9, 2022 | 12:26 PM
Kbovee's Avatar
Kbovee
Default 2012 crew ETC light
Have a 2012 Durango crew 3.6L. While driving, intermittently will stall. Rpms will fluctuate as its stalling like its starving for fuel, after, the ETC light and traction control light will come on. Will crank but not fire for around 10 to 15 mins. Ive replaced the throttle body and still the same thing. While it's cranking the rpms will jump a little. The ETC (lightning bolt) will flash. ETC and traction control light will come on at the exact same time. I have a video of the crank no start and what light are on but can't post here. I do have the recall for the fuel pump relay open so I will be getting that done bit from what I've read in other forums, that hasn't cured the issue so any info would be greatly appreciated
Thank you
Old May 10, 2022 | 12:06 AM
master tech's Avatar
master tech
Site Moderator & Tech
Did you do a ETC re-learn?
Old May 10, 2022 | 10:28 AM
Kbovee's Avatar
Kbovee
yes if you're talking about turning the key on and 5 presses in 5 seconds, wait and then 20 seconds. If there's another way then no
Old May 10, 2022 | 05:42 PM
master tech
That is resetting the oil reminder lamp. You will need a scanner to re-learn the ETC and you may as well does a re-learn on the crank and cam too.
Old May 11, 2022 | 11:31 AM
Kbovee's Avatar
Kbovee
I have not, did not know it had to be do e by a scanner..my scan tool does not do that but it is going to the dealer to get a recall done
Thank you
Old Apr 30, 2024 | 09:29 PM
dphunct's Avatar
dphunct
Default i have this exact problem with my 2013 Crew
Did the ETC reset work? Are there easy instructions somewhere?
Old Oct 13, 2024 | 11:12 AM
Holli's Avatar
Holli
Thank you
I had the same problem. Spent a lot of needless money and got all the codes to go out. Then, went old school. Changed all the spark plugs and then found the pcv valve was stuck open. Changed it out and no more stalling while driving. (The relay recall had already been done on mine and it still stalled.”
