3rd Gen Durango 2011+ models
2015 Durango R/T Valve tap
Old Mar 24, 2024 | 11:00 AM
RamedHemi's Avatar
RamedHemi
Default 2015 Durango R/T Valve tap
Hi my truck has 54K miles which is very low for this year and when I do a cold start I am getting a loud valve tap. After about one minute it goes away, but this is not normal. Last oil change I added Lucas product to help avoid something like this. Anyone else have experience with this? I know the pickups with Hemi in this model year range have many engine/valves tap issues almost everyone you see on the road you here the issue. Assume same motor.
Old Apr 18, 2024 | 11:58 AM
RamedHemi's Avatar
RamedHemi
The problem is not the motor, its right-side manifold. Guess a bolt broke. Won't be a cheap fix. UGH
Old Apr 19, 2024 | 12:55 PM
DDCREW's Avatar
DDCREW
Careful with using oil additives since the variable valve timing (VVT) and multi displacement system (MDS) rely on proper oil viscosity and proper oil pressure.
