3rd Gen Durango 2011+ models
Stalling at idle, 2013 Durango 3.6L
Old Oct 12, 2024 | 04:52 PM
Holli's Avatar
Holli
Default Stalling at idle, 2013 Durango 3.6L
I have a 2013 Dodge Durango SXT 3.6L motor. It was stalling while driving and throwing codes for many things. Erasing one code at a time, I replaced all 4 O2 sensors, both throttle position sensors(replaced throttle body and gas pedal), retired a cam shaft sensor and the plug for the throttle body. Car still stalling. Only code left was the catalytic converters. Replaced both. Still stalled. Changed spark plugs and also found the PCV valve was stuck open. Stalling while driving is fixed! No codes, no check engine light. Next day, tire pressure light comes on. All tires are fine. Car stalls at stop sign. It will rev beyond 3 and I have to let off the gas for it to shift. IDK what the problem is now. Replaced the fuel pump and the sending unit last weekend. Still stalls. I’m at the end of my rope with this issue and ready to trade it in. Any ideas????????
