3rd Gen Durango 2011+ models
3rd gen key fob
Old Oct 22, 2025 | 06:50 PM
hoeky's Avatar
hoeky
Default 3rd gen key fob
Anybody know the correct replacement ###'s for the proper fobs. I have a 11 ciditel. Or where can i find the proper #
thanks.
Old Oct 23, 2025 | 05:59 PM
SHO Rod's Avatar
SHO Rod
Do you have one that you know worked at one time? If so, open it up and check for the part number. It might be etched onto the circuit board.
-Rod
Old Oct 23, 2025 | 09:34 PM
Isn't the part number cast into the back side of the plastic housing??
Old Oct 24, 2025 | 12:11 PM
hoeky's Avatar
hoeky
The only part ## i see on fob board is---201611241430-5
Old Oct 24, 2025 | 07:07 PM
SHO Rod's Avatar
SHO Rod
Have you tried ordering a fob based on the year and model of your Durango? Are there more details here we're missing, like you ordered a fob that should work but were unable to program it or something?
-Rod
Old Oct 24, 2025 | 11:08 PM
hoeky's Avatar
hoeky
Originally Posted by sho rod
have you tried ordering a fob based on the year and model of your durango? Are there more details here we're missing, like you ordered a fob that should work but were unable to program it or something?
-rod
dodge wants a ton of $$$--$200+ i want to order from amazon.
Old Oct 25, 2025 | 10:54 AM
Get the dodge part number, google search on that. Chances are good you'll find on for a LOT less.
Old Oct 26, 2025 | 09:58 AM
SHO Rod's Avatar
SHO Rod
It's been awhile since I've added fobs to a 2011 Dodge. You should research what's needed to program additional fobs to your Durango. If you only have one working fob you may need to program using a scan tool, and if you don't have that, the dealership's $200 rate may not be so bad if it included programming.
-Rod
Old Oct 27, 2025 | 09:45 AM
hoeky's Avatar
hoeky
it's been awhile since i've added fobs to a 2011 dodge. You should research what's needed to program additional fobs to your durango. If you only have one working fob you may need to program using a scan tool, and if you don't have that, the dealership's $200 rate may not be so bad if it included programming.
-rod
i have 2 new fobs coming.ill have a great mech shop program them and go from there.
