View Poll Results: Headers
Kooks
6
3.77%
Borla
9
5.66%
Dynaflow
0
0%
Edelbrock
10
6.29%
Pacesetter
44
27.67%
Hooker
7
4.40%
JBA
29
18.24%
Headman
6
3.77%
Dynomax
3
1.89%
Gibson
17
10.69%
Doug Thorley
3
1.89%
OTHER (please specify in a post)
25
15.72%
Voters: 159. You may not vote on this poll
Headers
  #21
Old 09-21-2009, 11:10 AM
Mega-Hemi's Avatar
Mega-Hemi
Mega-Hemi is offline
And that is off thier website. I'd feel more comfortable seeing an Indy w/o a bias opinion doing a test.
  #22
Old 11-01-2009, 09:02 AM
TheFist's Avatar
TheFist
TheFist is offline
Originally Posted by Scarriere
I went to JBA's website (cause that's what i've got) and checked out their dyno numbers.
Baseline: tq peak is: 304
hp peak is: 248
w/JBA headers:
tq peak is: 318
hp peak is: 263
tq gain: 14 lbs/foot
hp gain: 16 hp
Obviously this is at the rear wheels.
Is that for short tube?
  #23
Old 11-01-2009, 11:51 AM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
About 20-25 HP gain is generally what I see the actual dynos being with Long Tubes, significantly less with Shortys.
But it's an accumulative thing, added to a CAI and better muffler and the numbers can go up significantly.
  #24
Old 11-01-2009, 04:19 PM
ThunderedRod's Avatar
ThunderedRod
ThunderedRod is offline
TTI Long Tubes with their Y-pipe and high flow car-sound (magnaflow) cats. A pretty penny but I think worth it. I have a 4wd and a different cat-back but this is the Gains from a dyno sport truck did.
TTI Truck System
2006 Dodge Ram 5.7L Hemi
2WD / Quad-Cab / Shortbed
An independent test performed on the Westech dyno chassis using our Complete 5.7 Hemi Truck System (TTI 1-3/4" Header, Cat-Back Y-pipe Assembly and 3" Exhaust System), showed an incredible gain in horsepower and torque over the factory stock manifolds and exhaust.
--------------Stock------TTI system ------- increase @ 3500RPM
Horsepower:---165 hp------205 hp----------- + 40 hp
Torque:-------248 ft. lbs.----309 ft. lbs.------+ 61 ft. lbs.
I am not sure why sport truck only reported the gains at 3500 Rpms. Personally I would like to see the whole curve.
I dont think I gained near this much power. The biggest difference I notice was some low rpm power and now it really moves when I get past 4500 RPM all the way to the shift at around 6000RPM
Here is the link for the sport truck article http://www.sporttruck.com/techarticl...ust/index.html
As soon as I get some extra cash (not going to be anytime soon haha) I will try and get my truck dynoed to see really what kind of power I am making.
  #25
Old 11-01-2009, 10:49 PM
lb79theone's Avatar
lb79theone
lb79theone is offline
Location: Maine! ( GET A HOLD OF ME IF YOU WANT TO GET ME ON FACEBOOK.COM, AND CARDOMAIN.COM)
I see no point in shortys other than saying you have headers and also get a better look than the stock manis, right? If you bother to get headers get the longtubes! My opinion, thats all.
  #26
Old 11-02-2009, 07:22 AM
TheFist's Avatar
TheFist
TheFist is offline
Don't long tubes seriously screw with your emissions? There's no getting around that here in NM unless you live on the reservation. Which I don't.
  #27
Old 11-02-2009, 11:00 AM
ThunderedRod
No LT don't unless you dont have the right cat set up. I cleared emissions with no problems.
  #28
Old 11-02-2009, 12:05 PM
truckin151's Avatar
truckin151
truckin151 is offline
If you have a visual inspection of your system the LT's will flunk you everytime unless you go to someone that will "over look" them. You are moving the cats from the stock location which is a federal law. If you live in a state that either does the sniffer test or just plugs into the OBDII port and checks for irregularities and emission fault codes you'll be fine.
  #29
Old 11-02-2009, 10:30 PM
lb79theone's Avatar
lb79theone
I will see in Febuary.
  #30
Old 11-03-2009, 07:51 AM
TheFist's Avatar
TheFist
TheFist is offline
OK, thats good to hear. I can probably get away with them. How much more in cab noise at highway speeds do they add? Stupid question if you want headers I know. But, I do tow with my truck pretty regularly and I'm curious about the noise under load.
Quick Reply: Headers
