Superchips Questions and Updates
Old Oct 20, 2010 | 03:22 PM
  #2661
s13_marine's Avatar
s13_marine
Yeah, Scott just emialed me back about it. Pretty disapointing that it's just the 2004's. Would be my luck. Hopefully they can resolve it at some point. Jay, I sent you a PM with my email. Thanks brother.
Old Oct 20, 2010 | 11:11 PM
  #2662
s13_marine's Avatar
s13_marine
I inputted JustJay's shift schedule and it works very well. I'm going to move up 5th gear a little bit tho, because it still shifts very early into 5th just cruising around town. Other than that it's good.
What has everyone done with the "Low Shift Schedule" How is this different from the other shift schedule? I noticed that there are many of the same throttle % values under some gears but the shift point range is lower at the same throttle %..... anyone have a Low Shift Schedule you'd like to share?
Old Oct 20, 2010 | 11:17 PM
  #2663
glass3222's Avatar
glass3222
Low shift schedule is for 4x4 in low range.
Old Oct 21, 2010 | 08:50 AM
  #2664
s13_marine's Avatar
s13_marine
I have a 2wd
Old Oct 21, 2010 | 08:57 AM
  #2665
glass3222's Avatar
glass3222
Then low shift schedule will not do anything on your truck
Old Oct 21, 2010 | 07:16 PM
  #2666
s13_marine's Avatar
s13_marine
Hmmmmmmmmmmm........... I wonder why they left it in there as an option?
Old Oct 21, 2010 | 07:48 PM
  #2667
glass3222's Avatar
glass3222
It is just part of the program that you buy when you get the advance trans tuning, it is not something that is added per individual vehicles. It is the same as with my Diablo, it has MDS on/off, I have an 05, no MDS, it is just built into the program but will do nothing whether you adjust it or not.
Old Oct 22, 2010 | 08:08 PM
  #2668
m3summ's Avatar
m3summ
Default switching to tow mode?
Hey guys, I currently run the 87 tune with my own custom shift schedule. If I change it to tow mode to tow my boat home tom. will I have to re-enter my shift schedule when I go back to it? Also my boat weighs 3700lbs. plus my tandem trailer. I filled up with 89 octance will I be ok just switching it to tow mode and rolling? Thanks
Old Oct 24, 2010 | 11:45 AM
  #2669
freddy53's Avatar
freddy53
I do believe that 91 octane is required for the tow/haul mode.
Old Oct 25, 2010 | 09:03 AM
  #2670
Scott@Superchips's Avatar
Scott@Superchips
Former Vendor
Correct, 91 is recommended to keep pinging away when the vehicle is under load in that setting.
Scott
