Superchips Questions and Updates
im looking at putting the superchips chip in it, dont know wich one yet
i have an 06 dodge ram HEMI 4x4 with the fuel managment system
if i buy this chip, will it affect the performance of the fuel managment system?
it shuts down 4 cyls while not in the throttle above 35mph and i know the chip gives better mpg, but will it help or affect the performance of the fuel managment system?
The unit is a full blown tuner, not a "chip". It will not effect the ability of your MDS unless you choose to disable the function...
I talked with superchips yesterday when I was trying to log onto their Flashpq site and they said they are probably going to be shutting it down. I couldn't get registered when I tried, so i gave them a call. Every time I tried to register, it just sent me back to the SC main site. Just thought I'd let everyone know.
I was able to regiater the tuner through the main SC site, but when i tried to use my username and password at the flashpaq sit, it wouldn't let me log in. I had to call SC for another issue and they told me then that it wouldn''t be long before they stopped using the Flashpaq site completely. Said they were just going to use the main SC site for all of the info.
Matty, when you talked to them did they say anything to you about the new beta version of their updater that they are currently testing? That might be why you can't register. I downloaded the new beta version of the updater yesterday and my passwords stopped working for the updater and flashpaq forum. I had to call them to get my passwords straightened out. Maybe that has something to do with your not being able to register.
Then again the last time I updated on Vista I got version 1.32/database 239 but didn't have datalogging so I tried updating right after that on XP and got version 1.31/database 236. It seems I went backwards in updates with XP but the datalogging update worked.
The updater worked fine on my Vista machine before using their beta version. I've since uninstalled the beta and tried the regular updater on Vista and still can't log in. I can still use the updater on XP so I haven't had the need to call Superchips about it.
Same here. Tried using the beta version of their updater and my password stopped working on my "Vista" computer but for some reason still works on my "XP" computer???
And I still can't log into the flashpaq site. When I try to it tells me that my username does not exist. Then when I try to log in as anew user, it sends me to the main SC page, and I can't find a place to log in besides registering my flashpaq again. Don't really know what if any info is available on the site, so its not that big of a deal.
I've noticed that it makes my MDS kick on and off when I'm driving at a constant speed. I really noticed it when I was driving across Alligator Alley with my cruise set at about 65; every few seconds, it would kick it off, then back on a few seconds later. No real change in speed, but you feel it just enough to where my head would bob a little bit each time, and of course you can hear it with my exhaust. It started to drive me a bit nuts, because Alligator Ally is about as straight and flat of a drive as you will find. I decided to get used to it, but if I were taking a trip across the midwest I might think about loading the stock settings back in.
If you’re noticing MDS during cruising under certain operating conditions (like Alligator Alley), I suspect you’re right at the factory on/off thresholds and should consider either deactivating MDS or switching to the SAVE setting. Either one will move the on/off limits out of the cruising range you’re experiencing. I’d recommend the SAVE setting for those ‘straight and flat drives’ since you’ll be using more 4-cylinder mode to maximize fuel savings. Of course that’s not as fun as the Performance file...
Stay tuned.
i was playing with tunes today "thank you hammer for the help" and i noticed nothing with the 91 tune except the shift points . i switched to the tow tune and i deffinatly felt a difference. better thottle response and a 0-60 time 0f 7.3 sec. my question to the superchips guys is why is the tow tune better seems to me the tow tune should be the "performance tune" better throttle response IMO . im running 93 oct and in all i think im sold on the tow tune not the performance. IMO the performance tune is for 4k and up rpms ...now who driver at thoes rpms all the time i want kick *** throttle response and performance witch i get out of the tow tune. the performance just doesent do it for me its to close to stock. i had the diablo for a day then didnt want to drop a tranny so i replaced it with this ...was i wrong?
