Data Loggers
Old Jun 24, 2010 | 10:33 PM
  #741
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by 03MopaRamman
If best pre Cam Data-Log was 5.6 them my guestamation is that teach will hit the 5.25 to 5.3 Range with traction and similar conditions (parameters spare on/spare off) or as Red says if he can "Hook-up" which I am yet to understand since I cannot spin mine,,,Yet! LOL
That is hard to believe. You really need to do the TMR mod. It's free and will make a hugh difference.
Old Jun 24, 2010 | 10:37 PM
  #742
RedTruck-VA
Originally Posted by Off_Road_Teacher
You are right, nothing like that on the truck. I just launch in 4wd hi, or at least that is what I did when I pulled my best time.
If that is what works for you, stick with it.
Old Jun 24, 2010 | 10:46 PM
  #743
truckin151's Avatar
truckin151
Oh yeah in similar conditions I fully expect to see him in a low 5 sec 0-60, but 90's and high humidity is not the same or similar conditions.
Old Jun 24, 2010 | 10:50 PM
  #744
Off_Road_Teacher's Avatar
Off_Road_Teacher
I agree with truckin. When the weather is good again I am hoping to see a few tenths gained over my previous times. But with this weather that we have now, I don't think that I am going to see that kind of gain.
Old Jun 24, 2010 | 10:57 PM
  #745
03MopaRamman's Avatar
03MopaRamman
Ok, ya don't miss that Humidity as spoiled out here in the Banana Belt, but A/C is my freind too, That gives you time for the TQ and by then its Halloween and cool...and
Old Jun 24, 2010 | 11:01 PM
  #746
Off_Road_Teacher
I hope you are right about me being able to get a converter by halloween. That is the next thing I really want but don't know if I will be able to swing it by the time winter rolls around. From all the things that I have read and heard, a new performance converter really wakes up these trucks.
Old Jun 24, 2010 | 11:03 PM
  #747
RedTruck-VA
I think it'll run great. Intake air temp stays pretty stable with a good warmed up engine and the humidity will reduce knock.... She'll run...
Not as good as a nice cold morning, but you got what you got...
Old Jun 25, 2010 | 12:28 AM
  #748
truckin151's Avatar
truckin151
The humidity will squeeze some time off but thats maybe a tenth, the real killer is that he is jumping near 50* in temperature between one run and the other which is huge and that there is what will hurt him more than anything. It will absolutely run great there is no question about that BUT I do not expect much of a change if any under those conditions.
Old Jun 25, 2010 | 06:32 AM
  #749
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by RedTruck-VA
Maybe we can start paying closer attention to our inlet air temperature. To see what effects it is having on our runs. Side note, I have an appointment to reflash my PCM tomorrow and reset the ABS warning. I guess I'll try th Diablo afterwards to see if is still a problem. Talked to the local performance engine builder today about cylinder heads. He told me the set up would be heads, 6.1 springs and custom push rods to establish optimum rocker arm geometry determined by the specific cam used. I haven't heard anyone say anything about any valve geometry issues but has anyone really checked this with the various cam installs?
With a non adjustable valve train, in reality a push rod length checker should be used to get accurate VT geometry. When I built my 350 in my 442 I used a Comp Cams full roller rocker adjustable VT and had to go through all of that in setting it up. It (for me) was a big PITA but that was partly because it was my first one.
But as a general consensus of the board, because the 6.1 push rods and springs work, everyone just goes with it. There is more science behind it but because it works everyone just goes with it.
Old Jun 25, 2010 | 09:28 PM
  #750
Off_Road_Teacher
Took the truck out for a run tonight. The temp was 86 and the humidity was 64% (I got this info off of weatherbug), running about 3/4 tank of gas and had a little bit of lumber in the bed. I did run into a little problem as they have put a rumble strip along the edge of the highway that I like to do my timed runs on. It slowed me down off the line as I was about 13 hundredths slower to 60' than I was last time when the road was smooth. Guess I am going to have to try to find a new spot to do my runs at. Anyway, here is the readout from dynolicious.
