Going to try this E-Cutout - Raceland Switch-N-Blast
Old Oct 7, 2009 | 07:40 PM
chefred112's Avatar
chefred112
wow..wireless..that would be cool if you standin outside the truck and open it...would freak peopl out...
Old Oct 7, 2009 | 08:00 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I guess you could leave it in the truck but if you are like me and have remote start then you would want to have it on you so when you do remotely start it you could open and close them to play with them. Its a nice selling touch but not one I would pratically use.
Old Oct 8, 2009 | 03:10 PM
bwhite757's Avatar
bwhite757
Ok, got a reply back from the guy with some better pics, here you go. I will take more obviously when I get mine in:
After seeing these, I'm a little excited now to receive it...
Old Oct 8, 2009 | 03:20 PM
SilverBullet08's Avatar
SilverBullet08
looks pretty cool. im thinking ill get a dump tube for the valve part just to point the gases down
Old Oct 8, 2009 | 03:24 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
damn, looks good to me. Might have to get one. I can see how these guys cut the cost out of it and are able to sell it cheaper, and it's not anything bad.
Old Oct 8, 2009 | 03:28 PM
SilverBullet08
yea it looks like its built pretty good. i read some problems with the dmh and how the valve or motor breaks sometimes...
Old Oct 8, 2009 | 04:14 PM
oefootball_70's Avatar
oefootball_70
hey bwhite757, since you are already in contact with them, would you mind sending them an email asking if they make a 2.5 inch cutout?
Old Oct 8, 2009 | 04:28 PM
bwhite757's Avatar
bwhite757
http://www.racelandus.com/p-24-racel...ic-cutout.aspx
There you go...
Old Oct 8, 2009 | 04:30 PM
truckin151's Avatar
truckin151
The only real issue I can see with that cutout is if/when the valve either burns out or it starts slipping. Seeing how everything is welded together if something goes bad and you have to send it in to get it fixed, or buy a new one you'll have to take that whole piece off. So if it was welded in place, that means cutting it off and having to patch your exhaust til it gets fixed or you buy a new one.
With the ones like DMH has, if the valve goes its an easy 3 bolts and its off and you got a plate to cover the hole til you get a new one. Also being able to take the valve off to clean it up, make some tweaks to it opens/closes correctly is also a very good thing as well.
I will admitt though to be able to remotely open and close it would be very very slick.
Old Oct 8, 2009 | 04:35 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I have to say that I can not wait to see this thing in action and hear your first hand review. If it works and is made well it could be a good, less expensive alternative to the DMH.
