Rant!
Old Aug 17, 2010 | 09:47 AM
Beastro's Avatar
Beastro
Exclamation Rant!
sitting in traffic in virgina and my truck is over heating! i have to keep the heat on and its 80 out. going to look for an efan in orlando any know a junk yard there?
Old Aug 17, 2010 | 12:43 PM
PhotogTom's Avatar
PhotogTom
Did you check your thermostat?
Have you changed your coolant lately, and maybe need to "burp" the air bubbles out of the system?
Radiator clogged with bugs?
The stock fan should be able to cool the engine under most any condition.
Old Aug 17, 2010 | 01:20 PM
AWE Daniel's Avatar
AWE Daniel
yup bud somethings wrong there, my truck never overheats and im in florida
Old Aug 17, 2010 | 02:48 PM
Beastro's Avatar
Beastro
****. il have to check all the cause even driving down the road now its right in the middle. it was working fine befor i left.
Old Aug 17, 2010 | 03:19 PM
PhotogTom's Avatar
PhotogTom
I had a thermostat stuck on my 99 Exploder (I sure have a lot of Explorer stories) - stuck closed or mostly closed. It was on a trip back from Ohio to Tennessee. The last 100 miles of my trip, I had the heater blasting full to cool the engine. It worked, but it was definately running close to the "hot" end of the gauge.
Swapped out the t-stat and it was fine. Funny thing, I replaced the factory "made in Germany" with an Autozone "made in China" thermostat. Didn't see that coming!
It's not advisable to continue to run with it hot like that.
Old Aug 17, 2010 | 05:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah checking those rad hoses and rad cap is the first and more simple thing i would do. From there I would pull the stat and run w/o it to see it that helps. If so then replace the stat. If not then I would start maybe looking at the fan if you are getting hot at idle in traffic but not moving down the road.
Old Aug 17, 2010 | 06:13 PM
MikeHTally's Avatar
MikeHTally
Unless the fan clutch has failed.
Old Aug 17, 2010 | 09:55 PM
PhotogTom's Avatar
PhotogTom
True, Mike. Hadn't thought of that.
You should have strong airflow through the radiator at idle if the fan clutch is properly engaged.
Old Aug 17, 2010 | 10:04 PM
RedTruck-VA's Avatar
RedTruck-VA
The eFan won't resolve an overheating problem unless it is a failed fan clutch. Are you running normal temperatures at highway speeds? If so, than it looks like the fan clutch is shot. Try turning the fan by hand with the engine off. There should be considerable resistance. If not then it really looks likethe fan clutch has gone south. If the fan clutch id working ok, then start checking the system. Rad cap not holding pressure will cause a problem. Does the radiator have cold spots? good luck...
Old Aug 18, 2010 | 01:05 AM
Beastro's Avatar
Beastro
i got florida late. but at highway speeds the temp would be norm for few hundered miles then would run just past the middle. il check it all in the am. thanks
