Power Inverter Install
Im looking to install a power inverter and im trying to figure out were the hell im gonna hook it up. was wondering if anyone had any good ideas were i could install the inverter so i can have easy access. granted under the seat works but i was looking for more of an in-dash install like this one
https://dodgeforum.com/forum/3rd-gen...mall-mods.html
...I put mine under the passengers front seat.Its a 400 watt converter for my laptop and my "vac "orbital buffer" coffee pot and what ever else i may need ..Its a great Mod __________________
well i hooked up my 1200 watt inverter under the driver seat and built a lil bracket so it stays horizontal and stays flush with the front seat cross member thingy
also ran 2GA wire and the wires are about 9FT, manual says 3GA for 6FT and 0 GA for 10Ft think i should be fine? i pushed the inverter to the limit and had no issues also installed a 200amp ANL fuse too..... pics will follow
Trending Topics
lol nahh i hit up advanced auto-parts and auto-zone and they didn't have anything figured id to that until i could find a grommet to put there. luckily the caulking is easy to remove as it just peels off
know any place that might have a grommet
also not sure if i like the location of the fuse. i put it there since its easy to get too but i dont think it looks too clean and i gotta paint the sheet metal screws black but in due time
Hi Paratrooper. I have a 2006 Ram 1500 and want to install an inverter like you did. Can you please show the wire route from the battery to the inverter? I am trying to figure out how to route the wires and I can’t figure out where you drilled those 2 holes and how you routed your wire to the inverter. Any help is greatly appreciated!
