Squeaking and Ticking Sound from Rear
Question for the masses. I have a 2005 Dodge Ram 1500 4x4 Quad Cab with the 4.7L and 100,900 on it. Lately I will hear a small squeak coming from the rear of the truck when going slow in reverse. Then in drive upon takeoff there will be a ticking sound like metal rubbing or hitting something coming from the rear as well.
After doing some research, read that it could possibly be the u-joints either front or back. Well I checked them out today and they were both tight and had no play. Could the u-joint still be bad even if there is no movement?
I notice the noise after the truck has been sitting for a long time and a cold start. Doesn't do it when the truck is hot.
Any other possible ideas would be greatly appreciated!
Thanks,
James
Thanks,
James
This past weekend didn't service the differential because couldn't find 75/140 gear oil anywhere after 6 different stops. Was able to find it yesterday after work so will be servicing the rear this upcoming weekend.
As for the squeaks and ticking, its resolved. It got really bad on Friday of last week and stil ujoints seemed tight. Bought them and since I hadn't done them before and my dad doesn't have a vise, took it to our local shop. they replaced the front and rear ujoint and noises are completely gone. Also the vibration in the drivetrain is gone as well.
Thanks for the help! Like I said before, the ujoints were tight but still were pretty much shot when removed.
