Heads-up for Rough Country Wheel Spacers
Old Aug 30, 2010 | 01:55 PM
JMaxx93's Avatar
JMaxx93
Default Heads-up for Rough Country Wheel Spacers
I ordered some 1.5" wheel spacers from Rough Country that arrived pretty quickly. When I ordered them I specified in the "What vehicle is this for" box that it was for my 05 1500 Ram, blah blah.
Turns out Rough Country only has 1/2" diameter wheel studs for our bolt pattern. We (at least my truck) use 9/16 wheel studs. Also, my factory chrome capped lug nuts don't fit inside the opening for the spacer. A different open end lug nut doesn't fit with enough clearance to get a socket around it. And tuner lug nuts would probably fit, but they would probably cost over $100 for 20 of them.
Rough Country sells them for a great price (under $140 for 4 shipped to me). But with the extra $100 I would have to spend on lugs to make them work, it would be more desireable for me to just purchase some Soft 8 17" wheels for $80 a piece. Only problem with them is that they are 8" wide from what I've seen and I don't think I should squeeze a 315 tire on a 8" wide rim. I think my factory 17" is 8.5" wide... Anyone?
Just my FYI on how to be a broke pimp and still lift your truck.
Old Aug 30, 2010 | 02:43 PM
dirtydog's Avatar
dirtydog
Moderate User
Other Chrysler vehicles and Dodges use 5x5.5" pattern with 1/2" studs(i.e.Jeep) so it's possible they mixed up an order or someone pulled the wrong product? Is there a sticker on the box that says otherwise?
Factory 17 is 8.5 and 315 is too wide for an 8" rim.
There are plenty of 9/16" studded wheel spacers in the 5x5.5" pattern if you really wanted to go that route? 1/2" is 8/16" so 9/16" would be larger. You def don't want to go smaller, besides, new lugs would be very difficult.
Old Aug 30, 2010 | 09:47 PM
HammerZ71's Avatar
HammerZ71
Soft 8's are available in 17x9 in a 5 on 5.5" pattern, have had my hands on them and the price tag on them was $71 a piece plus $12 for the center cap...
Old Aug 30, 2010 | 10:10 PM
oefootball_70's Avatar
oefootball_70
yeah, thats what I was about to say. I almost ordered a set when I was looking for wheels earlier this year.
Old Aug 31, 2010 | 09:29 PM
JMaxx93's Avatar
JMaxx93
I recall seeing the cragar soft 8's in 9". But from what I remember they were only with 5.5 backspacing...
Old Sep 1, 2010 | 10:34 AM
hoss67's Avatar
hoss67
will be ordering my set of soft 8's by the middle of next week.... if im understanding right about the lug nut issue, the lug nut that come with the spacers go on the original studs and ur chrome lug nuts go on the spacers studs, and also if u order another set ur probably going to have to shave the original studs off some thats what i had to do, so when i get my soft 8's i am going to have to get 20 original studs for my truck but they are only 1.69/ one...
