Ram 1500 for towing
Old Aug 30, 2010 | 09:33 PM
airford1's Avatar
airford1
Default Ram 1500 for towing
I just bought a 2007 Ram 1500 Regular Cab/short bed 5.7 auto with the tow package.
I intent to use it to tow my drag car to the strip and want to hear from the voice of experiance on what to expect. I really couldn't afford the larger DSL and am hoping the Hemi would be up to the challange of pulling5500lbs of car and trailer.
What do you think?
Old Aug 30, 2010 | 09:44 PM
HammerZ71's Avatar
HammerZ71
I pull a 7700# tractor about three or four times a year with no problem whatsoever although it does suck the gas quite a bit...
Old Aug 30, 2010 | 10:07 PM
HemiRam1566's Avatar
HemiRam1566
i have the same truck and it seems to pull my boat which weighs about 3000lbs very well. cant see it having an issue with a car trailer loaded
Old Aug 30, 2010 | 10:34 PM
thomasnchy's Avatar
thomasnchy
No problems yet here, and I pull a 6,000# skidsteer on a 1200# trailer on occasion. My only worrie is the revs... I'm still not used to spinning 5200 before a shift (up hill, and trying to not be a nuisance on the road)
Old Aug 30, 2010 | 11:25 PM
Marx's Avatar
Marx
ya 5500lb is a joke for the hemi i also have 3.92 gears that help
at about 7000lbs you will start to feel it
if you have the tow package you should also have 3.92 gears and being a RCSB you have less weight than me to begin with
when i tow my car and trailer, 4200lbs (and 500lb in the bed) i use the tow haul button and my RPM's basically stay at 2000 the entire trip. and will jump to 3500-4000 to get up a medium sized hill
Old Aug 31, 2010 | 12:32 AM
bgbluram2's Avatar
bgbluram2
I tow a 27ft. camping trailer with my Hemi, I have 3.92 gears and it tows it fine. The trailer weighs about ~6300 lbs. dry and can weigh as much as ~8200 lbs. when fully loaded (water, gear, food, etc) No problems. Pulls it much better than my 2000 F150 did.
Old Aug 31, 2010 | 04:14 AM
rickof08's Avatar
rickof08
What do you think?
I use my truck for the same purpose. I have a 87 Supra that I pull on a 18ft trailer 60 miles every week and I have no problem at all with my truck. You have a regular cab so you should have an even easier time than me.
Old Aug 31, 2010 | 07:41 AM
airford1's Avatar
airford1
Thanks guys, when I started looking for a tow vehicle I concentrated on Silverados, because the new fords are bu tt ugly, then I saw a short Hemi and it started stick. The more I looked into it the more I liked the Dodge.
I'm lovin it so far. My drag car is a ford BB and the kid next door saw the Hemi and said " anit that a bitch", your tow vehicle is faster than your race car!
Old Aug 31, 2010 | 07:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said before, you will have no issues. I also use mine to pull a loaded 16ft trailer from time to time
Old Aug 31, 2010 | 10:27 AM
AF_HEMI's Avatar
AF_HEMI
i pulled a canoe last week and had a real hard time with it.
