Building a 5.7 liter SINGLE TURBO
Old Aug 31, 2010 | 06:36 PM
  #21
RedTruck-VA's Avatar
RedTruck-VA
I don't worry about 18 wheelers, but them souped up Mustangs are a bit tricky....
Old Aug 31, 2010 | 06:39 PM
  #22
runvs's Avatar
runvs
haha well yeah i shouldve added those too....and about those bullet civics !!! gotta watch out for them ! lol my buddys gotta nasty one
Old Aug 31, 2010 | 06:58 PM
  #23
freestyledude's Avatar
freestyledude
I know someone who turbocharged a quad with a leaf blower. It actually worked pretty well, eventually blew the motor lol
Last edited by freestyledude; Aug 31, 2010 at 06:59 PM. Reason: to many lol's, it was ridiculous
Old Aug 31, 2010 | 07:05 PM
  #24
marksman1500's Avatar
marksman1500
Originally Posted by runvs
im sorry didnt understand about the oil pump, but i know i gotta pump the return oil up to the motor electronically, and can you explain the 2 additional injectors a little more i didnt get it completely about splicing i understand the fuel line part, and what controllers ? what do you guys recommend ?
The oil pump is what will pull the oil out of the turbo and push it through the line to return back to the motor, without it, the oil will not flow back to the motor, this is a VERY special pump to do this (part of the STS secret). The 2 additional injectors will feed off of a "T" in between the main fuel rail and the feed from the tank. You will need to control these two injectors as to when the come on (under boost, and at what PWM rate (Pulse Width Modulated) meaning in laymans terms how much fuel flow at three axis points, (X) RPM and (Y) Load vs (Z) Psi of boost, the "controller" will allow you to "dial in" your fuel flow to these two injectors when the truck sees boost.
Around here, I will be your turbo god LOL. I hold a few world records for turbocharged vehicles.. Yes no joke..
Old Aug 31, 2010 | 10:07 PM
  #25
runvs's Avatar
runvs
Ok so this controller and 2 injectors u talk about ? What is it going to cost and how hard is it to hook up. And the oil pump....what type of pump do I need to get ? And how do the injectors hook up to a fuel source like without a rail? Is there a fitting or trick to do I understand the t part .....any pictures ?
Old Aug 31, 2010 | 10:08 PM
  #26
runvs's Avatar
runvs
And get ready to help cause I'm going turbo.!!! And I appreciate it
Old Sep 1, 2010 | 12:36 AM
  #27
irishcarbomb's Avatar
irishcarbomb
extra injector controller
http://www.sdsefi.com/eic.html
also look into megasquirt, i used it on a previous turbo project
Old Sep 1, 2010 | 10:13 AM
  #28
runvs's Avatar
runvs
so do i need to go with the 2 or 4 injector setup ?
Old Sep 1, 2010 | 09:40 PM
  #29
FrostKing's Avatar
FrostKing
And your best recommendation is aux. fuel injectors?? Yikes.
Old Sep 2, 2010 | 02:04 AM
  #30
marksman1500
I have built several aux. inj. controlled vehicles, and it is the best solution for those who do not have the ability to get a QUALIFIED tuner on the dyno. 3d mappable aux. injector controllers are easy to use if you understand how to read, and can grasp A/F ratio concepts.
I have built and still build 1400+hp turbocharged vehicles, all the way up to Top Alcohol funny cars. So the Yikes comment? Yeah, YIKES!! when I fire up the KB 481 LOL!
