tire load range.
Old Sep 5, 2010 | 12:58 AM
dodgemudder's Avatar
dodgemudder
Default tire load range.
i have a 2005 dodge ram 1500 4x4 and am wondoring what the best load range is for tires. im thinking of getting the 265/70r17 cause i think that is the stock size. correct me if im wrong. and getting the goodyear wrangler duratrac and want to know what load range, C or E to get? for you guys who have them or know. how many miles does the C range tire last and the E range tire last. any help is greatly appreciated. thanks.
Old Sep 5, 2010 | 03:32 AM
Marx's Avatar
Marx
i would go E range if you do any sort of hauling to towing, i always like to go alittle higher than the max of the truck that way there is a lesser chance of a blow out
C is a 6 ply tire and E is a 10 ply tire
amount of miles depends on what the tire is made of and how you drive
also be aware of the Load index as a lower load range you need a higher load index
give this a readhttp://en.wikipedia.org/wiki/Tire_code
Old Sep 5, 2010 | 09:09 AM
dirtydog's Avatar
dirtydog
Moderate User
You don't need E-range even if you are doing towing hauling as the factory has already taken that into acccount. If you are needing a heavier tire to handle wha you are hauling, then you are past your legal limit anyways. C or D range tire is perfectly suitable and will give you a better ride than an E(very stiff sidewalls), PLUS they are cheaper.
I'd go with a C-load tire if it was me. If you are going offroad frequently, then yeah, go for an E-load because offroading consists of rocks scraping your sidewall and that is where E-load tires will benefit you.
Marx, load index is load index. Doesn't matter if it's a C or E. If a C range is 123 and so is the E, they carry the same weight, but that will never be the case. It's when you get into putting car tires on a trailer when that's the case as a trailer tire of the same load index can carry 40% more weight than a car tire of the same index.
Old Sep 5, 2010 | 10:56 AM
HammerZ71's Avatar
HammerZ71
I run a D load range Dick Cepek tire and have yet to need a plug. Pulled a few nails/screws out of 'em up around the farm, but none have ever made it all the way through. Been lucky, all have hit a block and not the void areas, so they'd have a ways to go puncture all the way.
This land has had barns and such on it since the late 1870s, has had many outbuildings and re-roof jobs done, so there is debris, nails, screws, sharp pieces of steel, etc. all over the place.
Mostly pavement driving with a bit of recreational off-road, you'll be fine with a C rated tire, and will have a much smoother ride on the road...
Old Sep 6, 2010 | 11:06 PM
dodgemudder
will the load range E tire last longer on my truck or the C load range or will they be the same or what?
Old Sep 7, 2010 | 06:54 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I forget what mine are but I need to go check. I know they are heavy tires though. LOL
Old Sep 7, 2010 | 07:28 AM
HammerZ71's Avatar
HammerZ71
I've seen both claim to last longer. The C's because of more "give" and and less rolling resistance and the E's because they are a harder compound.
Personally, I don't think think wear would be enough of a factor to consider one over the other.
It be more of a how you plan to use them decision. Heavy tow/haul then go with the E's, ride quality then go with the C's. Or do what I did and find you a set of D's, kinda compromise between the two...
Old Sep 7, 2010 | 09:03 PM
Marx's Avatar
Marx
your right i didn't mean it as a ratio and it's all IMO
i meant if he used a c he might want a better load index to prevent blow outs since its a lesser ply tire
tires is onething i go over board, i have seen to may tires blow that i want to be safe
Old Sep 7, 2010 | 10:54 PM
dodgemudder
i do quite a bittowing/hauling and offroading during hunting season. mud, rocks sand you name it. but im not haed on the gas unless i have to. thats why i was thinking E range. and i dont mind a harder ride just need a good solid pretty tough tire that can hold its own offroading in mud, rocks
