Y-Pipe ?
Old Sep 30, 2010 | 09:23 PM
  #21
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by cjs4444
Wow it actually was worse....how does that happen?
Sitting the two cats side by side it is easy to see the OEM single cat is much larger in diameter allowing a greater surface area for the exhaust to flow through. Now if I was going to gut the cat I would sleeve the Magnaflow cat as it is smaller in overall size and fits nicely under the truck. The state vehicle inspection does a visual inspection on the cat so I have to at least have the body installed. I will probably stick with my basic plan and just use the single OEM cat behind headers and "Y" pipe.
