Lets see some numbers
Old Oct 6, 2010 | 02:53 AM
DaytonaDakota's Avatar
DaytonaDakota
Default Lets see some numbers
Here is a crappy pic of my 2006 mega cab 1500 4x4
it has a 2 inch revtek lift
315/40/26 wheels pretty much 36"s
just trying to see what im looking at for the NJ stability test with height measurements
i plan on lifting soon and ive heard nj is getting very strict
since my truck is over 7500lbs i can go 11 inches but i have know idea what the original height was the inspection station says they measure from ground to bottom of the door
any truck pics lifted or not i need to see ovh(original vehicle heights) of trucks as well i plan on just stopping at dealer or something
the first pic is from ground to tip of driver door 23 1/4"
second half of the pic is ground to the tip of the passenger front fender 43 1/2"
Old Oct 6, 2010 | 08:02 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im following you but what exactly are you wanting or asking? Do you want someone to measure their stock height for you so you can compare?
And you got 315/40/26?? Biotch you had better go get me some more pics of the rig because I want to see them. Some guys dont like trucks with big rims but I do. Ive got 24s and want 26s but no one makes the tires i want in the size i want
Old Oct 6, 2010 | 10:22 AM
dirtydog's Avatar
dirtydog
Moderate User
First off, you need mudflaps if you need to go through a lifted truck inspection. I believe the lifted inspection is for anything over 4" above factory specs??
Anyways, HERE's a thread where I helped a guy while back cheat the inspection station and get a normal non-lifted inspection. i suggested slapping on temporary teenie tiny wheels/tires.. Do you still have the factory wheels/tires?
Looks like you need to be at 24" or below for a normal inspection(which you are) for the 1500's even though you have a Mega, it's still classified as a 1500 in DMV books.
Old Oct 6, 2010 | 12:08 PM
dirtydog's Avatar
dirtydog
Moderate User
I found THIS regarding NJ lift laws. check it out.
Old Oct 6, 2010 | 08:37 PM
DaytonaDakota
i bought the truck about 2 months ago with the 26s and the 2inch revtek leveling kit
mud flaps are must to pass inspection but they are my last concerne
i just bout a 3 inch pa body lift because it was only 335 shipped
i plan on goin way higher like adding a 4-6 inch lift but i gotta becareful to be legal
and yes weed i do plan on keeping the bigg ole wheels on with the lift i like lifted trucks with big wheels as well
basically i wanted to see any measureents stock height or lifted heigh aslong as modifacations are noted
thanks for all the nj test info too
