Electric Rear Slider
Old Oct 18, 2010 | 05:54 AM
redpurusuit78's Avatar
redpurusuit78
Default Electric Rear Slider
http://www.truckininstyle.com/Index.htm
Has anyone use one of these from this company? Any info would be appreciated!
Old Oct 18, 2010 | 06:18 AM
5point7 hemi's Avatar
5point7 hemi
I bought one about 2 years ago. Still holding up fine with no issues.
Here is what you have to do...
Remove the back seat. (the hardest part of the whole job.)
Remove the OEM window and cleanup the glue as much as you can.
Put down the glue primer and lay down a bead of caulk and fit the new window in.
Finished with window install.Reinstall the seat. 24 hour cure time.
While that is drying, you can mount the motor behind the back seat, against the wall and connect your push pull cable.
Last, Route the wires along the drivers side to the emergency brake. Route the power and ground through the bulkhead to the battery. Tie it all up nice and pretty and mount the switch. Done
Old Oct 18, 2010 | 06:22 AM
redpurusuit78
Thanks for the info!!
Old Oct 18, 2010 | 06:36 AM
Mega-Hemi's Avatar
Mega-Hemi
Do you have to run it directly to the battery or can you run it off an accessory so it's only on with the key?
Old Oct 18, 2010 | 06:56 AM
5point7 hemi
You can run it any way you want. I prefer to wire it hot so I don't need the key to open or close it.
Old Oct 18, 2010 | 12:20 PM
dakota_raven's Avatar
dakota_raven
That will be on the list to do on my dak!!! $410.00 not bad!!!
Old Oct 18, 2010 | 12:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Nice pics and walk through. Looks like it turned out really well.
Old Oct 18, 2010 | 01:36 PM
Mega-Hemi's Avatar
Mega-Hemi
Weed, maybe this could be made into a DIY??
Old Oct 18, 2010 | 03:29 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Would be great but wold you like to have/know more detailed info?
Old Oct 18, 2010 | 03:31 PM
Mega-Hemi's Avatar
Mega-Hemi
Yeah, I'm sure 5point7 hemi could add more to it if he knew it was going to the DIY thread.
