performance help
Old Nov 15, 2010 | 10:49 PM
SilverBullet08's Avatar
SilverBullet08
Originally Posted by fascistfaction
What is the point of exhaust headers if the flow is restricted from the cylinder heads? A cold air intake and cat-back exhaust are mild and will gain 10-20 horsepower. An aggresive cam, ported heads and a tuner will yield 100 + (with the CAI and cat-back),
FF
have u seen the stock manifolds....
Old Nov 15, 2010 | 10:55 PM
AF_HEMI's Avatar
AF_HEMI
in case anyone is interested...
Old Nov 15, 2010 | 10:57 PM
SilverBullet08
ur not the only one
Old Nov 16, 2010 | 09:09 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I have changed out the manifolds for TTI long tubes in my Demon and Coronet and I have JBA shorties on my Durango. The headers are a hugh improvement over the manifolds, but a ported head will and cam shaft will be a night to day.
Old Nov 16, 2010 | 09:18 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
FF
100 what? Horses? Nah....wont get you that much.
Ive got all that and a few more small things and Im willing to safely bet Im not 100 over stock.
Old Nov 16, 2010 | 11:07 AM
SilverBullet08
a cam needs headers to get the full potential out of it...
Old Nov 16, 2010 | 12:25 PM
1969CoronetR/T
vaffanculo
It will get 100 + easily on the Hemi if you use a cold air intake, tuner, headers, cam shaft, ported cylinder heads, and cat-back exhaust as my Durango dynoed close to 480 horsepower....not sure about other engines. If power is wanted and money is not a problem, I would go with all the above,
FF
Old Nov 16, 2010 | 04:58 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well I still dont think so but IDK honestly. I know Ive got all those mods and then some. But as soon as i finish my tuning Im hopping on the dyno so I will do a thread on it
Old Nov 17, 2010 | 02:44 PM
AF_HEMI's Avatar
AF_HEMI
FF im gonna disagree with you again. If you want power, go big valve heads, not ported heads. Ported heads are a "mid-grade" option. BV heads are a little bit more, but if you're gonna spend the money, do it right. Thats like buying shorty headers when you could get longtubes.
I agree with you as far as a cam and heads being big boost in power, but c'mon get real, this guy is just getting into performance. heads/cam is NOT the place to start.
Its becoming painfully obvious the guys that know what they're talking about, and the guys that... well the guys that that just dont. Good input weed
Old Nov 17, 2010 | 04:04 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Keep in mind those that use BV heads are usually aluminum CNC'ed heads that are also P&P'ed. If you are dropping 2k+ for a set of those heads you are going to go all out.
