Need to know max. Towing capacity
i have a 08 1500 4x4slt quad cab 5.7 hemi w/20" rims and 3.92 axle ratio.My question is i am buying a travel trailer and would like to know the max. towing capacity? I know that on the trailer ill have to install a weight distribution system to lower the tw but what can i pull safely?
thanks
thanks
Look at the VIN for the vehicle. The forth position will be the GVWR of that vehicle. (L=9001-10000 M=10001-14000 any letter lower than these is even less load) You also need to figure out what class hitch is on it.
http://www.usa-trailer-hitches.com/hitchclasses.htm
Don't forget to take into account the weight of what goes IN the trailer, and the truck as well. It can add up QUICK!
Trending Topics
The class of hitch has nothing to do with the truck's rated towing capacity. Neither does GVWR. It's the GCWR that is relevant. For a guess, I'd say the all-up trailer weight can't be over 8,000# A bunch of stuff in the truck will reduce that.
thanks
thanks
