Rear Diff. Clutch Plate broke
Old Dec 28, 2010 | 10:46 PM
The Cank's Avatar
The Cank
Default Rear Diff. Clutch Plate broke
yeah it sucks... Good news, I LOVE ME A WARRANTY !!!
Old Dec 29, 2010 | 07:18 AM
MikeHTally's Avatar
MikeHTally
Rear diff. clutch plate?
Old Dec 29, 2010 | 08:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, we need more info or pics. In fact, both are needed.
Old Dec 30, 2010 | 12:57 PM
The Cank's Avatar
The Cank
I'll have pics as soon as I get it pulled out. yeah there are plates in the rear diff and the clip is broke causing them to slice into the clutch. it also trashed the Posse. Now when I had it at my friends shop to drop it off I was on two hours of sleep after a 15 hour day at work so I may have some of this messed up but I will get the exacts on the 4th of January when we pull it all apart again. I am by no means a transmission guy so I may have some things wrong. I won't know till I talk to my friend Who ownes the transmission shop
Old Dec 30, 2010 | 08:28 PM
MikeHTally's Avatar
MikeHTally
Oh, you're talking about the LSD clutch packs. That is the "Posi". If you can afford it, put in an Auburn or a DTT.
Old Dec 30, 2010 | 10:41 PM
The Cank's Avatar
The Cank
I will look into the other LSD. If they are only 400 bucks or so I will jump on it
Old Dec 31, 2010 | 09:53 AM
dirtydog's Avatar
dirtydog
Moderate User
The rear diff is isolated from the transmission and a transmission specialist is not going to know exactly how to do diff gears. I just want to make it clear to you since it seems you don't fully understand? Also, the posi unit is part of the carrier. The clutch plates are a part of the posi and is how the posi works. These parts are located inside the carrier and yes, it ends up ruining much of if not all of the internals inside the rear dif including the gears.
Besides, if you have a warranty, why are you even touching anything yourself? I would think your warranty is void if you start to do anything yourself? Might wanna check that out before going to crazy.
Old Dec 31, 2010 | 01:22 PM
MikeHTally's Avatar
MikeHTally
You'll find them to be in the $800-$1,000 range by the time they're installed.
Old Dec 31, 2010 | 05:04 PM
The Cank's Avatar
The Cank
My friend ownes a transmission shop so warrenty work will go through him I am just gonna be there to see how everything works. The more I look into it the more I am just gonna stick what was in there back. No different gears. I don't want to shell out 1000 bucks
Old Dec 31, 2010 | 06:50 PM
slimvela's Avatar
slimvela
Are we talking factory or one of them used car warranty deals? If factory, first I've seen them allowing an "outside" shop handling warranty claims/ work.
Subscribed
